  1. It still sounds like you've got a chip on your sholder or something.
    I've used the EZCD 'VIDEO' menu cheat to burn Xvcd with EZCD, and it works fantastic...with a little work!
    Keep looking on this forum........
  2. Guest
    pure motion editstudio supports video in video,
    dont know if that helps for video menu support
  3. Member kabanero's Avatar
    Feb 2001
    HockeyTown
    Hi Steel,
    VideoPack 4 and WinOnCD 3.8 PE can make menus from MPEG-1 video clips. And it will be:
    VIDEO XVCD MENU.
    I do this all the time. Also, they don't complain about non-standard MPEG-1 file. I always encode with 2400Kbits/sec for video bit rate. Personally, I think that VideoPack 4 is the best for XVCD.
    Salute.
  4. Actually, I have posted in this forum a very simple method to create either still picture menu or motion video menu with optional music background.
    This method works well for VCD, SVCD, XVCD, XSVCD and I am still using this approach today.
    If you have a burning software that supports VCD, SVCD, XVCD, XSVCD then it's going to work whether the burning software supports menu or not.
    <font size=-1>[ This Message was edited by: ktnwin on 2001-07-02 14:41:27 ]</font>
