I understand that registry trick can allow for custome resize as well giving size close to 4.37 or about that so its not undersize. My question is do i need to configure the registry trick like the scroll on DVDAnalyzeMaxRel, DVDAnalizeMinAbs, DVDSavequality and other options a well?
If so how should i configure to get the size close to 4.37 GB? also since the max is only 4.32 GB on IC, with this registry trick do i just use that max or any other size in IC to get close to 4.37 GB?
