I am trying to open a video that requires media player 9 to play. It plays fine in media player and BSPlayer but I can't open it up in VirtualDUB. It says it needs a WMV3 codec. I am not sure where I can get this or if VirtualDUB can even open it up anyways. Does anyone know how I can open this video in VitualDUB?
THANKS
Results 1 to 9 of 9
As I recall, only an earlier version of Virtual Dub can open a .wmv file. I believe it was version 13c. Search the web, and you may still be able to find it.
Hello. -
OK the main problem is that I can't open it up but any version of virtualdub says it can't find the supported codec the movie is using. it says cannot find WM3 decoder or someting along those lines
The reason I ask this is because the movie is 800MB so it won't fit on 1 cd so I need to compress it to 700MB but I can't since I need thw WM3 codec or whatever that is, SInce virtualdub can't open it because of this I can't do anything. Need help
"wmv3" is the four character code (FOURCC) for media encoded with the Windows Media 9 Codec. I would start by making sure you have all the proper video codecs installed for Windows Media 9. Start here:
http://www.microsoft.com/windows/windowsmedia/9series/codecs.aspx
You might try reinstalling (or installing) the latest version of Windows Media Player. This should automatically get you up to date with the latest codecs.Open WIDE for Chunky!!! -
http://download.microsoft.com/download/9/8/a/98a6cb2d-6659-485e-b1f9-2c0d9bf6c328/wmv9VCMsetup.exe
i can now open .avi files that have a fourcc of wmv3
Wmv3
By Shiyow in forum EditingReplies: 2Last Post: 15th Jul 2010, 11:49 -
WMV3 to TS or M@2TS
By teknix1 in forum Video ConversionReplies: 0Last Post: 30th Dec 2008, 09:24 -
Faulty wmv3 (9) codec problem
By Darius_bd in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2008, 17:30 -
WMV3
By Bassalisk in forum Video ConversionReplies: 3Last Post: 19th Aug 2008, 20:24 -
WMV3 support in future?
By paulwillis in forum ffmpegX general discussionReplies: 2Last Post: 28th Jan 2008, 13:10
