i have some mpeg1 movies i've downloaded, they play just fine in qt. but toast will give that regular vcd error abou not liking it. so about 20% of the time i can just demux and re-mux the video and then toast will like it. when that doesn't work, 80% of the time i could use missingmpegtools, and use the vcdxgen and vcdxbuild to make a burnable file. but with these files none of these options work, so i was curious if there were any other options that i'm missing to try, with out having to re-encode these. any help would be greatly appreciated.
thanks
pants on, pants off, pants the floor.
use VCDGear and apply a MPEG2MPEG conversion. There is an option to make a "Toast" compatible mpeg file in there.
This should work.
http://homepage.mac.com/bauer.w/vcdgearx/ -
thanks for that, i forgot all about that program. i still ran into a few that wouldn't work though, any other thoughts?
pants on, pants off, pants the floor. -
Lock has been unlocked after discussing with pants.
his movies are legit "free" for all downloads
but for those wondering, typically you will get this problem because you are downloading movies that are ILLEGAL!
so for those you get ZERO help - and a warning.
Per this..... all i can say is I usually do a mpeg to mpeg with VCDGEARX and that clears it up
if it doesnt still, it may just be you cant use this one, sorry. -
pants, i looked at some of the things on the site, you could perhaps get something other than the format you have, and then convert that (ie divx) into mpeg.
then it would work most likely -
duh, that makes sense. i usually just grab th mpeg1's cause that's quickest.
thankspants on, pants off, pants the floor. -
no problem.
Sometimes a round about way is the best. In this case I think this will fix your situation.
AVI mono movie too big to burn on to single layer DVD-other options?
By nzdreamer55 in forum Authoring (DVD)Replies: 7Last Post: 29th Apr 2011, 14:45 -
DVD Flick Won't Burn whole Movie/movies
By armani_coke in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2010, 14:07 -
tv-movies won't open full screen
By xbill in forum Video Streaming DownloadingReplies: 2Last Post: 21st Mar 2008, 11:10 -
New guy, movies won't play on certain DVD players?
By koreninja in forum DVD RippingReplies: 6Last Post: 12th Oct 2007, 23:53 -
Philips DVDR 3390 won't let me fast forward DivX movies
By guiri in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Sep 2007, 04:28
