Newbie alert!!
Trying to read all of the 'guides' I can find, and it's getting dizzying....
Just want to clarify the basic process is:
- Capture it
- Edit it
- Convert it
- Burn it
So, you should be doing all of the editing (removing commercials, adding effects, transitions, etccc), before it's converted?
Thanks all
WjWm
Yes that is correct!
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
If you ARE able to do all that after it's converted
I will send you money for the method.
convert HD to SD for edit +burn
By Ellie3 in forum Newbie / General discussionsReplies: 0Last Post: 15th Nov 2010, 00:13 -
Edit then convert VOB to .AVI? Best way?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2010, 16:16 -
MOV files, cant open to edit/convert
By haggisuk in forum Video ConversionReplies: 3Last Post: 12th Oct 2009, 11:16 -
Audio edit from GarageBand does not convert to FLV
By mbrando in forum Video ConversionReplies: 8Last Post: 16th May 2009, 11:48 -
Edit DVD and convert to WMV
By Mdoodm1000 in forum EditingReplies: 3Last Post: 27th Feb 2009, 16:05
