when i start to watch a movie on my computer , i click on the file and then all of a sudden my monitor start to click and flash and the resolution changes on the screen and i have to reset the monitor to fit the screen properly ,,, i've scanned for virus's and come up with none ,,, it only does it to certain movie files and nothing else.
anyone shed some light on why and how to stop this from happening??
thanks , gordow
Sounds like whatever software player you are using is trying to adjust the screen resolution for the movie it is playing and the monitor doesn't like being tinkered with.
I know with some players are machines even, when you want to play DVD, the resolution has to be set to 800x600.
You might be running into something like this. -
that's the resolution that i have my system set to all the time ,, it's really weird , it just started happening with certain movies and not all.
thanks for the reply
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 19:31 -
How weird. Two movies, one ok, one all messed up
By LWC in forum Authoring (DVD)Replies: 2Last Post: 1st Jan 2010, 18:21 -
Weird horizontal line on top of the black area when playing movies(screen).
By Nitrius in forum Software PlayingReplies: 2Last Post: 23rd Aug 2008, 14:12 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
R5 movies / weird Wikipedia entry
By ambrosechapel in forum Off topicReplies: 3Last Post: 30th Dec 2007, 22:28
