What is the best way to back up each of the 6 disks onto 6 DVD-R Disks
DVDxCopy Xpress wants to only grab one episode from a disk
DVDxCopy wants to stretch it over two disks
I have ripped every episode to my hard drive. Thats right, all 24 of them.
I ripped them with the newest DVDDecrypter and they are all VOB format....is that right? Where do I go from here. I am willing to sacrifice a small portion of the quality to make 4 episodes fit a disk. I backed up Lord: 2 Towers with DVDxCopy Xpress, onto 1 disk, and noticed NO loss in quality even though it ate about 35 percent of the quality. So what program do i use to shrink the files and author 4 episodes onto one disk.
Any Help would be great.
you could try DVDShrink
there are 4 episodes on each of the 6 DVDs so why not put 3 episodes on each DVD and use 8 disks so the quality loss is less for the price of 2 blanks
you could put all 4 on 1 DVD, which I have just done yesterday and it's not the highest quality but it's still acceptable
try 4 episodes (only takes 20mins) and see of you like the quality before you burn, if not then just put 3 on a DVD -
The "best" way is to use the Big 3 (DoItFast4U, ReAuthorist, DoCCE4U). 24 Season 1 is a breeze to do with the Big 3. No funky DVD structure to deal with and you only have to IFOupdate 1 titleset per disc.
Needless the say the quality is awesome as well. -
If you have DVDXCopy Xpress then you should be able to download the latest version (3.0.2) for free. Then select the 'Entire Disk' option.
Do you have the link to download the new version of dvdxcopy xpress? I own the old version and would like to upgrade but I cannot find the site.
Try Here:
http://secure.smarterimage.com/solo/customers/
If that doesn't work, use
http://www.dvdxcopy.com/support/support.asp
and look near the bottom of the page where it says "Click Here To Login To The Customer Service Center"
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Easy way to default existing subtitle to "on" when backing up?
By Spoffo in forum SubtitleReplies: 1Last Post: 30th Jan 2011, 21:50 -
Problem "backing up" Confessions of a Shopaholic
By jamesprime4328 in forum DVD RippingReplies: 4Last Post: 3rd Sep 2009, 14:15 -
Problems with removing "Piracy is theft" sequence from 24 season
By Hamilton in forum DVD RippingReplies: 2Last Post: 10th Jan 2008, 20:25 -
Ripping "House, Season One"
By championjosh in forum DVD RippingReplies: 1Last Post: 3rd Nov 2007, 04:44
