Sounds like the field order set during the encoding process was wrong.
Try this:
Load the original capture file(I'm assuming AVI) into TMPGEN. It should analyze it and then should have a box that says field order A or field order B, switch it to the other one and re-encode. -
andkiich might have it right. I struggled for some time with DVD production because the video would get wiggly any time there was any motion from the camera. The solution was reversing the field order using TMPGEnc. After that, everything looked good. Another possible problem I've heard of but not experienced is the DVD media itself. If reversing the field order doesn't work, you might need to try different media. You can test the field order solution easily by just re-encoding a small portion of your original video. Good luck.
I feel the above is more apt, I guess the source file is something like 23.97 going to pal hence -1 frame equals stuttering.Originally Posted by kazz0817
Jitter playback on DVD player
By Mylo in forum Video ConversionReplies: 4Last Post: 29th Oct 2009, 07:21 -
Why Does One Mpg Jitter and One Doesn't? And Why The Jitter?
By abrogard in forum Video ConversionReplies: 10Last Post: 17th Nov 2007, 03:21 -
What DVD Recorder Corrects Tape Jitter?
By deuce8pro in forum RestorationReplies: 10Last Post: 21st Sep 2007, 23:52 -
'jitter' frustration on DVD
By hondo2160 in forum Authoring (DVD)Replies: 3Last Post: 21st Aug 2007, 21:16 -
Screen jitter when transfering from VHS to DVD
By Corey in forum DVD & Blu-ray RecordersReplies: 10Last Post: 31st May 2007, 18:43
