Ok I've had this drive, which came with my DELL, for about 8 months. Updated to the latest firmware. I still can't get it to burn @ x4
Can anyone how has successfully burnt x4 with this drive share their expericnce and let me know what burning s/ware you used & with what media.
Thanks in advance.
have the same drive on a WinXP system and it burns TDK 4x DVD+R at 4x. I buy the TDK media at BestBuy when it's on sale.
Bob W: what software do you use to burn the TDKs with?
Anyone else get x4 ok with this burner?
I've burned at 4x using Movie Star 5. I also used Sonic DVD. I assumed it was burning at 4x, but I didn't take note of the speed. Both times I was using Phillips DVD+RW.
Ok thanks guys. I'll try Nero on my cheap x4 media first. If thats doesn't work I'll try me some TDKs....
Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?
By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 12:24 -
daewoo dv-1100a region free hack
By noblegirl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Jun 2009, 19:18 -
NEC TV to Pioneer DVD not working well
By Prasanna in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2008, 05:19 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13
