I can capture at VCD quality and burn a VCD to play on my TV and, it's not
bad, considering the source.
Would I notice any difference if I captured at DVD quality and burned a DVD
of the same material?
I don't have a DVD burner yet, so just wondering.
Anonymous4374945Guest
Probably, but it will never look better than the source. Unless you are a wizard with filtering, then you may get a tiny bit of improvement over the source.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
The VCD standard is also legal for use on a DVD. So if you are statisfied with the VCD quality, you now can put LOTS of video on a DVD instead of "boosting" the resolution etc. If you are capturing from an analouge source... I'd think you'd get along just finde with VCD. Please note that XVCD is NOT legal, only the strict VCD standard (Red book??)
no, up to 1.8mbps is supported with MPEG1 on DVD, so higher than 1.15 for VCD. also, the sound must be sample at 48khz instead of 44.1khz.
Ditto to the LaserDisc-King.
And, for the record:
White Book v1.0 - Karaoke VCD
White Book v1.1 - VCD
White Book v2.0 - VCD w/PBC
White Book v0.9 - SVCD
(Glad to see Philips can count in the right direction! :P) -
I'm no wizard but I have found that using the filters available in ATI Multimedia Center while capturing TV shows in vcd quality makes a huge difference. I'm can put 7 hours of TV on a DVD and it looks great.Unless you are a wizard with filtering, then you may get a tiny bit of improvement over the source.
I can make pretty good VCDs with my setup. Good enough that unless it's a show I REALLY like, I just make a VCD of it.
My favorite format is 1/2 D1, though. But VCD is still pretty good.
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 19:49 -
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 02:42 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18
