My config : Kt7a-raid abit athlon 1400é1600
256 ram, geforce ddr and so on...
I try to make vcd from a vhs.
I use s-vhs cable.
With win98, 2k and xp, the problem is still the same, awful video and distorded sound(like a modem or a fax !!!)
sometime color video, sometime black and white with color part.
i tried everything, install last driver and three differents windows.
Someone has a clue for me ?
If Live Is A Long Way To Death, is Death A Long Way To Another Life ?
First, the audio has nothing to do with the WinTV card if you're captureing using S-video. So, check your sound card. Do not plug line level audio into the MIC input! Plug the audio into Line in and adjust the record level on your sound card.
As for video, select S-video input, NTSC if you're in the US, or PAL if you're in Europe. Adjust your brightness, contrast and color saturation so you get a correct looking image.
Then, start working on your capture program. Select the capture format like video resolution, audio capture format, compression and so on. There are a lot of adjustments that have to be set correctly before you get a good capture. I'm of course assuming your hardware is installed and working correctly.
my picture is looking great when i look in the wintv windows and the sound is correct too.
My connection are well done.
i'm a pal user so i use pal bg parameter.
but the final mpg is horrible.
A friend told me that when you use vcdconverter just after capture, it normally take +-10 min for a movie (1h30). me, it take 4 hour with my 1600Hz !!!!! Even tmpgenc freeze when i'm trying to convert.
i had made over 800 conversions from divx to vcd, so i'm not so newbie but now, i don't understand what's happen
Big audio problem
By gynno in forum AudioReplies: 6Last Post: 18th Feb 2012, 21:39 -
Big Problem
By k_pratl54 in forum DVD RippingReplies: 7Last Post: 9th Mar 2010, 20:37 -
big problem with soundmax
By marlo in forum AudioReplies: 6Last Post: 23rd Jan 2010, 03:40 -
HandyCam > PC > VDM! Big problem!
By ChezDigital in forum Video ConversionReplies: 26Last Post: 23rd Jul 2008, 22:23 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
