say if i capped a clip at 352x288, then i cropped the bottom of the video to remove noise/border, and then encode at 352x288.
is quality in the oringal image lost due to the picture being "stretched" due to the cropping ?
would it be better to clip the border, or leave it how it is ?
ice_2003
Yes.
If its just a few pixels you're cropping, either would probably be fine. Id suggest encoding a 30second clip both ways, stretching and adding a border, and burn it on a CDRW and compare. I doubt youd really notice any difference. Plus due to TV overscan, theres a chance you wouldnt even see the bad pixels to begin with, So Id throw that on the CDRW too.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
The quality will suffer due to the re-interpolation that has
to be done to stretch it. It is howver not necesary.
You can just simply paint the bottom black a few lines. 2 ways in Vdub:
1. Fill - paints black on a selected rectangle
2. Crop followed by add-borders. (this is in resize filter)
I need help with cropping!
By UnD3R0aTh in forum DVD RippingReplies: 23Last Post: 23rd Mar 2010, 01:33 -
Cropping...
By bsuska in forum Video ConversionReplies: 40Last Post: 15th Jul 2009, 15:27 -
cropping
By mwh99 in forum EditingReplies: 2Last Post: 7th Nov 2008, 12:25 -
Cropping DV
By bsuska in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2008, 10:31 -
cropping
By exekutive in forum ffmpegX general discussionReplies: 5Last Post: 25th Aug 2007, 00:02
