  1. Hi can anyone help me here i swear ill have no hair left,lol Problems with DVDx after i load ifo (rip or from cd) with any P4 options turned on program crashes wanting to send report? if i turn off all p4 options it will load ifo but upon convertion (vcd or svcd) i will have 2 disc ones of film? even b4 convertion if i use slider to preview film after about 1 hour it reverts back to start of film but slider is sitting half way thro film?
    i have everyupdate possible windows,aspi 4.60 etc.
    my comps specs:
    Compaqs P4 2.4
    512DDR ram
    120gig hard disk
    Toshiba 1502 dvdplayer
    Compaqs P4 1.4celeron
    512DDR ram
    120gig hard disk
    Everthing worked fine on my old dell P4 1.8 im begging to think its a compaqs problem? anyone else with a compaqs machine having same problems? anyhelp would be
    CaTcHmG
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    What operating system is it? XP? what model is your DVDrom? have you tried a google search of your DVDrom model number and DVDx problem as the search? Have you tried a different ripping program?
  3. my operating system is Windows XP,my dvd rom is toshiba 1502,both same which was in my dell P4 1.8 & everything worked fine?
    CaTcHmG
