Results 1 to 9 of 9
  1. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    okay, here's the deal, in gripping detail.
    I am trying to take some video footage and turn it into motion ascii art - similar to THIS. I want my output file to be a valid video file... avi, mpeg, etc., not a Java or txt.
    So far, I have found image-to-acsii convertors that will make the images I want, and will do batch conversions, but they output as text files.
    One of the programs supports taking the ascii text and exporting it back out as an image file, but it has no batch processing capability. If I can get a series of these converted, I can put them back together as a sequence of frames, and it'll all be hunky dory.
    What I need then is a way to automate the opening of the text file, and the outputting of the image files, so that I can turn it loose on a file folder and have it run through all the .txt files and convert them to images.
    Is there a way to do this with a batch file? Am I asking too much? I haven't worked with batch files, so I'm somewhat confused by the tutorials I've dug up - either they are aimed at someone with more knowledge of the process, or I'm just missing some crucial point.
    any info, leads or links appreciated.
    Thanks.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    batch file as in DOS box or command line batch?
    It can probably do what you want, in fact i'm pretty sure it can, it's just a question of hitting the right command. the only problem i see would be incremental filenames, i.e. you have have frame1.txt frame 2.txt frame 3.txt etc, which want to be converted to frame1.bmp frame2.bmp etc.
    Perhaps another option would be to use something like the sub station alpha plugin for vdub, which will overlay text like subs onto a video. simply open a blank video, load the plugin and set colours/sizing and let it go.
    i know for sure you could write a qbasic program to do it for you (i remember some of the commands in it), but i think qbasic disappeared after 98.........
  3. Well the firts thinsg you need to do is learn how to controll all your programs from the command line. i.e how to provide input and output filenames, set parameters and switches etc. If you can't do this, batch processing would be no use to you.
    I use batch files occasionally (mostly at work) and may be able to help if you can provide a little more detail, though I wouldn't be at all surprised to find others here with better knowledge of some of the more powerful command line features available in Win2k/XP compared to what was available in win9x.
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    flan -
    that's exactly what I mean.. that's one of those areas of computing that, since I didn't really touch a computer between the days of BASIC and the advent of Windows 3.1, I'm woefully ignorant about DOS commands, batch programs, working effectively from a command line, etc.
    I'll have to check the Sub Station Alpha - if it'll let me do top-to-bottom, side to side subs, it could work. Have you worked with it much? how big a pain would it be to put a text file in every frame?
    Thanks for the info.
    - housepig
    Housepig Records
    out now:
  5. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    @flan -
    did some checking on Sub Station Alpha ... man! that's some hectic stuff - I'm so glad I'm not an anime fan, some of that stuff would drive me nuts!
    I'm going to download it and play around, see if I can get it to format correctly.... if I can, sweet! life will be good.
    thanks for the tip.
    @bugster -
    I know, I know.. I need to learn more about working with DOS & working from the command line... you have any good resources for me?
    - housepig
    Housepig Records
    out now:
  6. googled
    here
    here too
    Hope these help
    Originally Posted by jagabo
  7. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    I used it for laying subs onto my star wars conversions, with hand written scripts (took a while!) and from memeory you just set a top offset and a left offset. so leave both as 0, an it'll just start in the top left corner.
    If you let us know the names of your programs, i will download and have a play, ascertain if they can/what the command line options are, and we can go from there.
  8. Instead of DOS batch files, use VBScript. More control and there are script sources you raid and learn from. Win98 and later have WSHost built in. (see WSHost on the microsoft.com site for details).
    see http://www.ericphlelps.com for some scripts.
    Here is a sample of a script I wrote. It opens a directory, scans for images, call a program to modify the images, creates a script file for avs, has a true percentage progress bar, and has a 'pick a file' for choices.
    Yeah it should be a program, but it grew as a I added stuff.
    ' This script processes images using ImageMagick (www.imagemagick.org)
    ' to prepare them for use as elements in a slideshow or video montage
    'Parts of this script are from www.ericphlelps.com
    ' Version 0.9.8
    'Notes
    'Use only copies of images not the originals
    'imagamagick must be installed  with the path c:\imagemagick or the script must
    '   be changed
    Option Explicit
    Dim Dir, cmds1, cmds2, fade
    Dim images(), menus, dt
    Dim bkgnd, avsstr, newfil
    Dim fs, avs, sh, wsh, ts
    Dim tv, framerate, res, w, h
    Dim fil 'As Scripting.Files
    Dim fils 'As Scripting.File
    Dim intCounter, intCounter2, i 'As Integer
    Dim gdocProgressBar 'Required global declaration for status bar document
    Dim goieProgressBar 'Required global declaration for Internet Explorer object
    Set gdocProgressBar = Nothing
    Set goieProgressBar = Nothing
    ' Define all the constants we will (or might) need
    Const TemporaryFolder = 2 'Scripting.SpecialFolderConst.TemporaryFolder
    Const ForWriting = 2 'Scripting.IOMode.ForWriting
    Const WshHide = 0 'IWshRuntimeLibrary.WshWindowStyle.WshHide
    Const WshNormalFocus = 1 'IWshRuntimeLibrary.WshWindowStyle.WshNormalFocus
    Const WshMinimizedFocus = 2 'IWshRuntimeLibrary.WshWindowStyle.WshMinimizedNoFocus
    Const WshMaximizedNoFocus = 3 'IWshRuntimeLibrary.WshWindowStyle.WshMaximizedNoFocus
    Const WshNormalNoFocus = 4 'IWshRuntimeLibrary.WshWindowStyle.WshNormalNoFocus
    Const WshMinimizedNoFocus = 6 'IWshRuntimeLibrary.WshWindowStyle.WshMinimizedNoFocus
    Set wsh = CreateObject("Wscript.Shell")
    Set fs = CreateObject("Scripting.FileSystemObject")
    'Check to see we got a folder to start with
    If Wscript.Arguments.Count = 0 Then
        MsgBox "Drop a directory on this script"
        Wscript.Quit 1
    End If
    Dir = WScript.Arguments(0)
    If Not fs.FolderExists(Dir) Then
        MsgBox "Drop a DIRECTORY on this script."
        Wscript.Quit 1
    End If
    Set fils = fs.GetFolder(Dir).Files
    ' Get the number of files to work on
    intCounter=0
    For each fil in fils
          If (Right(fil.Name, 4) = ".jpg")  Then intCounter=intCounter+1 : ReDim Preserve images (intCounter+1): images(intCounter)=fil
    Next
    i=intCounter
    'reset counter
    intCounter=0
    'get a backgound image
    bkgnd = BrowseForFile("Select Background Image:", "Select File")
    'type of transition
    fade = ChooseOne("Fade to Black" & vbTab & "Cross Dissolve" & vbTab & "Cut-n-Splice" & vbTab,"Transition" )
    'get pal-ntsc
    '-------use
    tv = ChooseOne("NTSC" & vbTab & "PAL" & vbTab,"TV System")
    If (tv="PAL") Then framerate = 25 Else framerate = 29.97
    '-------or
    'framerate = 25
    'tv = "PAL"
    '-------or
    'framerate = 29.97
    'tv = "NTSC"
    'get final resolution of montage
    '---------use
    res = ChooseOne("D1 DVD" & vbTab & "D1 Broadcast" & vbTab & "VCD" & vbtab, "Format")
    Select Case res
    Case "D1 DVD"
          w = 720
          if tv="NTSC" then h = 540 else h = 576
    Case "D1 Broadcast"
          w = 704
          if tv="NTSC" then h = 480 else h = 576
    Case "VCD"
          w = 352
          if tv="NTSC" then h = 240 else h = 288
    Case Else MsgBox "Format Error" : Stop
    End Select
    '---------or
    'res = "D1 Broadcast"
    'h = 720
    'if tv="NTSC" then h = 480 else h = 576
    '---------or
    'res = "VCD"
    'h = 352
    'if tv="NTSC" then h = 240 else h = 288
    '--------or
    'res = "D1 DVD"
    'w = 720
    'h = if tv="NTSC then h = 540 else h = 576
    'open file for AVS script
    Set avs=fs.createTextFile(Dir+"\montage.avs")
    avs.WriteLine("# read or edit using a fixed width font")
    avs.WriteLine("")
    avs.WriteLine("################################################")
    avs.WriteLine("#                                              #")
    avs.WriteLine("#              Photo Montage                   #")
    avs.WriteLine("# This creates a photo montage video clip,     #")
    avs.WriteLine("# also called a slideshow.                     #")
    avs.WriteLine("# This version is "&fade&"                #")
    avs.WriteLine("# between photos. Display time is set          #")
    avs.WriteLine("# using a constant. Image input is assumed to  #")
    avs.WriteLine("# be in the proper resolution and the pixel    #")
    avs.WriteLine("# aspect ratio accounted for.                  #")
    avs.WriteLine("")
    avs.WriteLine("")
    avs.WriteLine("#  Constants -                                 #")
    avs.WriteLine("#           This is to make it eaiser to       #")
    avs.WriteLine("#  modify global values. Mostly a standard     #")
    avs.WriteLine("#  header.                                     #")
    if tv="NTSC" then framerate = 30
    avs.WriteLine("FrameRate = " & framerate)
    avs.WriteLine("PluginPath = "&chr(34)&"C:Program Files\AVISynth2\plugins\"&chr(34))
    avs.WriteLine("width = "&w)
    avs.WriteLine("height = "&h)
    avs.WriteLine("FaderLen = 1 * FrameRate           # length of fade i/o frames (number=seconds)")
    avs.WriteLine("DisplayTime = 6 * FrameRate        # length of pic diplay in frames (number=seconds)")
    avs.WriteLine("")
    avs.WriteLine("")
    avs.WriteLine("#    Load plugins                              #")
    avs.WriteLine("LoadPlugin(PluginPath + "&chr(34)&"ImageSequence.dll"&chr(34)&")")
    avs.WriteLine("")
    avs.WriteLine("")
    avs.WriteLine("")
    avs.WriteLine("#     Main Script                              #")
    avs.WriteLine("")
    avs.WriteLine("# Cn are the image clips (n=1 --> some number)")
    avs.WriteLine("")
    'convert images and place on background
    For intCounter = 1 to i
    	 ProgressBar (intCounter/i)*100,"Image Processing"
    	 newfil = Left(images(intCounter),Len(images(intCounter))-4)& ".bmp"
    	 cmds1 = "C:\Imagemagick\composite.exe -gravity center -geometry 690x518 "&images(intCounter)&" "&bkgnd&" "&newfil
       cmds2 = "C:\Imagemagick\convert.exe -level 16 "&Dir&"\"&newfil&" "&Dir&"\"&newfil
       wsh.Run cmds1, WshHide, True
       wsh.Run cmds2, WshHide, True
    	 avsstr = "C"&intCounter&" = ImageSequence("&chr(34)&newfil&chr(34)&",1,1,"&fix(framerate)+1&").Loop(DisplayTime)"
    	 avs.WriteLine avsstr
    Next
    ProgressBar -1,""
    avsstr=""
    avs.WriteLine("")
    Select Case fade
    Case "Fade to Black"
        avsstr = "C0 = "
        for intCounter = 1 to i
            If (intCounter <> i) Then avsstr = avsstr&"FadeIO(C"&intCounter&",FaderLen) + \ "&vbCRLF	Else avsstr = avsstr&"FadeIO(C"&intCounter&",FaderLen)"&vbCRLF
        next
    Case "Cross Dissolve"
        avsstr = "Dissolve(C1,C2,FaderLen)"
        for intCounter = 3 to i
        avsstr ="Dissolve(last,C"&intCounter&",FaderLen)"
        next
    		avs.WriteLine("C0 = FadeIO(last,FaderLen)")
    Case "Cut-n-Splice"
            If (intCounter <> i) Then avsstr = avsstr&"C"&intCounter&" + "	Else avsstr = avsstr&"C"&intCounter&vbCRLF
        next
    Case Else Msgbox "Fader error" : Stop
    End Select
    avs.WriteLine("")
    avsstr = ""
    'resize montage to selected format
    avs.WriteLine("C0 = BilinearResize(C0," & w & "," & h & ")")
    if tv="NTSC" then avs.Writeline ("return C0.ConvertToYUY2.ConvertFPS("&framerate&")") else avs.WriteLine("return C0")
    avs.close
    'menu-thumbnails
    '    make thumbnails
        ProgressBar (intCounter/i)*100,"Making Thumbnails"
        cmds1 = "C:\Imagemagick\convert.exe "&images(intCounter)&" -resize 116x116 "&Dir&"\temp"&intCounter&".bmp"
    		cmds2 = "C:\Imagemagick\convert.exe "&Dir&"\temp"&intCounter&".bmp -bordercolor #101010 -border 90x90 -gravity center -crop 118x118+0+0 "&Dir&"\temp"&intCounter&".bmp"
    Next
    Progressbar -1,""
    '    make menus
    menus = Fix(i/8) + 1
    dim tempbmp
    For intCounter = 1 to menus
        ProgressBar (intCounter/menus)*100,"Making Menus"
    		tempbmp = intCounter*8-7
    		cmds1 = "C:\Imagemagick\convert.exe "&bkgnd&" "
    		if (tempbmp <= i) Then cmds1 = cmds1 + "-page +78+123 "&Dir&"\temp"&tempbmp&".bmp "
    		if (tempbmp+1 <= i) Then cmds1 = cmds1 + "-page +243+123 "&Dir&"\temp"&tempbmp+1&".bmp "
    		if (tempbmp+2 <= i) Then cmds1 = cmds1 + "-page +408+123 "&Dir&"\temp"&tempbmp+2&".bmp "
    		if (tempbmp+3 <= i) Then cmds1 = cmds1 + "-page +573+123 "&Dir&"\temp"&tempbmp+3&".bmp "
    		if (tempbmp+4 <= i) Then cmds1 = cmds1 + "-page +78+311 "&Dir&"\temp"&tempbmp+4&".bmp "
    		if (tempbmp+5 <= i) Then cmds1 = cmds1 + "-page +243+311 "&Dir&"\temp"&tempbmp+5&".bmp "
    		if (tempbmp+6 <= i) Then cmds1 = cmds1 + "-page +408+311 "&Dir&"\temp"&tempbmp+6&".bmp "
    		if (tempbmp+7 <= i) Then cmds1 = cmds1 + "-page +573+311 "&Dir&"\temp"&tempbmp+7&".bmp "
    		cmds1 = cmds1 + "-mosaic "&Dir&"\menu"&intCounter&".bmp"
        cmds2 = "C:\Imagemagick\convert.exe -level 16 "&Dir&"\menu"&intCounter&".bmp "&Dir&"\menu"&intCounter&".bmp"
    Next
    ProgressBar -1,""
    'Finished
    MsgBox "Done"
  9. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    stiltman & themichael -
    thanks for the leads & code! I'm totally open to VBS, hell, I'll draw a circle in chicken blood if it'll get this stuff done without having to open everything by hand!
    I'm so beat right now, I'm not going to get to play around until tomorrow night, but I know what I'm going to be looking up at work tomorrow...
    thanks again. man, I love this board!
    - housepig
    Housepig Records
    out now:
