Been a big fan of Tex Avery for a long time, so decided to buy the 'Compleat' LD boxed set (animation) and an LD player to play it on (with a view to backing up the set to DVD).
Thing is, I find the quality somewhat dissappointing. Things tend to be somewhat grainy throughout and the pictures seems to flicker ever so slightly as if the refresh rate isn't too hot.
Also, the picture on occasion seems to 'move' (as if the someone was filming the picture, but the camera was hand held.
And reds .... well, they're just noisy.
I've tried it on a few players (and with a few discs), and the quality is the same on both on my TV and when I try to capture to PC via my Canopus DVC-100.
Is it because the player is trying to convert an NTSC to PAL signal?
It's strange because the DVC will only work on NTSC setting while capturing - as if the player is omitting an NTSC signal.
I've never had a laserdisc player and was expecting the dogs b*ll*cks, perhaps DVD has spoilt me - but I remain generally unimpressed.
Anyone any suggestions?
Regards - Paul.
I suspect it's just a bad LD transfer, most likely because they couldn't find a good source to author from. I am (or rather was) into LD for years and the quaility was far superior to VHS or SVHS (eg. Star Wars CAV box).
Sorry but just sounds like bad luck on your part... -
depends on your disc and your player - all the laserdiscs I've transferred so far look absolutely gorgeous, but I have heard that some of the cartoon collection laserdiscs are hit-or-miss for the transfer quality.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I assume you're referring to the MGM boxed set of Tex Avery animation. I don't have it, but I'm familiar with it. And the quality should be very good.
I have several of the MGM "Golden Age" boxed sets of Warner Bros. cartoons and they are excellent.
Laserdisc to DVD capture questions
By bmwracer in forum Capturing and VCRReplies: 3Last Post: 8th Mar 2010, 12:04 -
Current recommendations for Laserdisc conversion
By tonyaldr in forum Video ConversionReplies: 3Last Post: 19th Jan 2009, 10:06 -
Laserdisc: Blade Runner
By vhelp in forum Off topicReplies: 11Last Post: 2nd Aug 2008, 00:19 -
LaserDisc to DVD!
By hellhole in forum Video ConversionReplies: 4Last Post: 1st Oct 2007, 03:07 -
LaserDisc to DVD with TmpgEnc Xpress 4.0
By sapulidi in forum RestorationReplies: 5Last Post: 16th May 2007, 13:42
