  1. Hi all, guess I'm haveing a "GIANT" brain fart on this subject, haveing read all that I can on useing this tool , ( not much there ) I still haven't been able to use it. Set up is this = rip with decrypter>filemode>movie only,, squeeze with DVD2ONE ,, try to turn back into .iso useing IMGTOOL to burn with decrypter. The reason I want to use decrypter is because it allows my Sony DRU500a to burn cheaper media than Nero or Copy2DVD does ( read that as less picky ) . All I can get is warning pop-up boxes . The VIDEO_TS files are there because I can see them .. Any help is appreciated.
    Roy
    PS.. can any one show me the correct context that goes in the boxes in IMGTOOL ? It is prob. just something simple that I'm doing wrong
  2. Member adam's Avatar
    Sep 2000
    You put the VIDEO_TS dir into another dir, then you load THAT dir into IMGtools. If IMGtools is saying it can't find the VIDEO_TS dir or anything like that, they you are probably loading the VIDEO_TS dir rather than the one it is contained in. Either that or your file structure may be incorrect.
  3. Thanks Adam will try that and see what happens.
    Roy
  4. I had the same problem when i first used IMGTool.
    Like Adam said all you have to do is put your VIDEO_TS in to another folder & then load that folder into IMGtoll & it will work Perfect
  5. Yep!! Thanks to all - it worked great!!
    Roy
