Hi everyone, I did a search through this forum, but couldn't find an answer to this question.
My DVD player (and TV) and my computer can read both NTSC and PAL DVD-Rs. However, I was wondering if there was an easy way for me to tell if the DVD-R I have is in either NTSC or PAL format. I know there are programs for the PeeCee that do that, but I haven't been able to find one for the Mac.
Thanks for any help!
Lynne
(I'm using Mac OS 10.2.6 with a Superdrive)
Drag one of the .vob files onto MPEG Info X, and it will tell you if the file is encoded in NTSC or PAL format. Download it from http://www.sbpr.a.se/systemjammers/mpeginfo/
Thank you so much! That works great; it's just what I wanted.
You guys in the forum rock!
Lynne
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
