Are there any authoring programs out there that can accept vobs?
I have dvd's i've made with Seinfeld episodes,and i want to take episodes from different dvd's,make a new menu and burn.I can save the selected vobs with dvd shrink into one file,but i need a program that will accept them to make a new menu and burn.
I have dvdws,but it won't take vobs.I opened them in vdub,saved as an avi,then made a compliant video with tmpge,but the quality deteriorated enough that i don't want to use that method.I tried frameserving from vdub,but i had audio sync problems.
Thanks for any help.
Brad
bmiller,ont.canada
DVD Lab can import and author vob files.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Originally Posted by bmiller
You can download the trial verson here
http://www.pegasys-inc.com/e_main.html"Can You Dig It!" -
You don't have the re-encode them to use them. I'm not sure what dvdws likes, but there are a number of programs that will demux the video and audio out. For example vobedit.
I personally think DVD-Lab is a good option. I just wanted to point out that you could most likely do what you want with dvdws.I mean it in the nicest way. -
NeoDVD will work with VOB files and AC3 audio.
http://www.mediostream.com/neodvd/index.html -
Thanks,i'll have to give a couple of these a try
bmiller,ont.canada
Need FREE DVD Authoring Software (Which Authors VOBs & Allows Menus Etc)?
By larrytxeast in forum Authoring (DVD)Replies: 15Last Post: 26th Jul 2010, 13:07 -
Authoring VOBs into Titlesets with Chapters
By matthewjohn23 in forum Authoring (DVD)Replies: 3Last Post: 16th Jan 2010, 14:24 -
Re-Authoring A DVD With LPCM>AC3 Audio & Fewer VOBs
By DeathStalker77 in forum Authoring (DVD)Replies: 5Last Post: 25th Dec 2009, 11:25 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52
