  1. Hi!
    If I do the main movie only and no compression is needed since the movie fits, do I have to perform deep analysis? If I do, will the pogram try to compress? I do not want compression since the movie fits.
    Thanks.
  2. No, deep analysis is not needed. It's basically going to rip the movie VOB(s) and the reauthor the IFO. That's if you have no compression selected.
    Phillip
    www.allaboutduncan.com
    "Oh, they have the Internet on computers now."
  3. Thanks!
    I'm doing my first movie with DVDShrink!
    Do you have any exprerience on the quality of the output if compression is used? what is the minimum you can go and not loose much quality?
  4. Depends on the source.
    Most movies, I'd stick with no more than 30-50% is possible.
    Old black and white films are a little more forgiving and animation, I've use 100% and it looks fine.
    If quality is a concern, use DVDFab to split it into 2 DVD-Rs.
    Phillip
  5. What version of dvdshrink is this? 2.3 is very nice.
    Jul 2003
    The Scottish Highlands
    Correct, but 3.0 beta 5 is even nicer.
