  1. Hello everybody,
    I have recently updated my Pinnacle sutudio 8 version with the latest patch : 8. something.
    Pinnacle claim they improve the out of synch issue during capture.
    Surprisingly, I cannot capture from analog source any more (or at least I can't find the right click to do it).
    The soft does not let me the possibility to choose (svideo, composite,..), I only have access to the DV
    I was just backing up my old family videotapes with my kids.
    Apart reinstalling the old stuff, does anybody has a suggestion ?
    Apr 2003
    Largo, FL
    Are you using the Pinnacle capture card? If yes, try reinstalling the drivers.
  3. Thanks for the answers
    No I'm using a AV/DV Twins capture cards that worked pretty well for both types.
    (except out of synch for AV so that I had to capture the tape by pieces of around 10 minutes (Quite boring)
  4. Originally Posted by franky111
    Hello everybody,
    Hi,
    Suggestion 1: Look in the manual. (I have the manual that came with the software, and I did actually read it... This one, however, escaped me for quite some time, till I stumbled upon it.)
    Suggestion 2: ok, here goes
    Select the first Tab labeled "1 Record".
    Click on the small TV-like icon to the left of the image in the bottom half of the screen. This opens up a screen in which to select the source you want to capture from.
    Click the TV-like icon again to close.
    I captre using the PCTV Pro card (analog video only), so I'm not 100% certain the software has the same options for other video cards.
    Anyway, this is my 5 (euro)cents worth.
    Frank
  5. Thanks frankb,
    I'll give it a try...
  6. Hello everybody
    I tried frankb's suggestion but I only have access to one button (tuner) and svideo or composite has disappear.
    I reinstalled the original studio 8 and all went back to normal.
    Is there any othe suggestion around
