I recently started using TMPEGEnc DVD Author to create DVDs. It's a nice basic program and easy to use, but I wanted to know if you can import your own backgrounds for the menus? I also heard that you can create motion menus. Anyone know how to use these options (I didn't see how to do it)?
Results 1 to 20 of 20
"Can You Dig It!"
To change the background double click on the background and select your image or mpg file. To use motion menu click the menu display settings button and go to the motion menu tab.
Thanks corwin102 for the quick response. I will try it out later tonight
"Can You Dig It!" -
in somewhat the same vein, in order to have background music does the background menu files have to be mpg or can you import wav/mp3 files to play in your menu's like you can with sonic mydvd?
Seems as though the audio has to be muxed with the video, so I don't see where individual audio files can be used in the menu
Yeah
The couple of times i have used still images i have just taken the audio i wanted and muxed them with the .jpg i wanted with TMPGEnc & then just imported them. if the audio i want to use is longer than the 15second menu time that is default in TMPGEnc DVD Author i just change the menu time to however long the background video is for the motion menus, like 29 seconds or whatever. -
I use TMPGEnc , close the wizard, put the .jpg in the video source & the .wav in the audio source then select the dvd template & encode, the video with the still & audio will be as long as the audio clip is, if you want it shorter you can go into the settings under advanced & choose "source range" and shorten it then use the audio edit to put in fade in & fade out so the audio does not just start/stop all of a sudden.
I actualy use Sound Forge for audio editing before hand but you can do it with TMPGEnc . this will only give you stereo sound but i figure you don't need ac3 or anything on the menus
That's a nice trick CHAOS! Thanks for the information. I have authored 3 DVDs with TMPGEnc DVD Author adding my own menu background, but haven't tried adding the audio yet. Each DVD is becoming an evolution of what I have learned
"Can You Dig It!" -
No prob.
Yeah, you can see the evolution of my dvd's through the first 5 or so, especially after they released an update for TMPGEnc DVD Author , 1.5.13.44 when they made it so you could move the thumbnails, text & links anywhere you wanted!!!
I also take diff. scenes from a movie, add them together, strip the sound off, then take just a music or sound effect track from the movie and put them together for menu backgrounds also, works out really nice!!!
when i first updated i actually re-authored a few to make the menus better.
Another thing i also do before even burning them is when TMPGEnc DVD Author makes the AUDIO_TS VIDEO_TS folders i check it with windvd to make sure everything rolls alright, it will play just as if it was on a dvd, i have said it before & i will continue to do so, this program is one of the best & easiest to learn & use!!! i don't even have use for any other programs with this, except dvd2avi & TMPGEnc for when i want to make movie backgrounds for the menus. -
Originally Posted by CHAOS
Also how do you move the thumbnails? When I click on the thumbs it just opens the thumbnail for editing."Can You Dig It!" -
You need to click on some button to edit the menu and it will ask if you want to crate a new one. You agree and it will take you to fully editable menu screen. You chose from many editable templates and create whatever you want. Then you go to the options tab and chose whether to have motion menus and for how many seconds from each clip or chapter do you want it to play. It's too simple for words!!!
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Originally Posted by jtoolman2000
it's the "Edit Menu Theme" button in the photo.
If you don't have that button on this screen you need to update to the latest version. -
Chaos.. It seems to me you are able to use motion background with sound successfully. I did the same, created a motion background with ac3, import to TMPGDVD but I get no sound only motion. Where did I go wrong? Can you help? Thanks
I Got A Question About DVD Author As Well...
I Imported My Two .vobs, Built The Menu Pages, Then Output The Project.
The Write Tool Errored At: (Actually States 100% Completed!)
5920 (of 2085136)
13696 (of 2085136)
Record Now Max Gives This Error:
Error -10 At Sector 800- Command:2A Sense:FF ASC:02 ASCQ:0E
Now, I Am Considering That The Problem Could Be Due To The Fact That My .vobs Are Varying Bitrates... (The Rates Vary Throughout Play).
The Output From DVD Author Plays Correctly Through PowerDVD.
Anyone Have Any Ideas On What The Cause Could Be?
Or Maybe A Suggestion On How To Burn The Project?
Boyd -
Guys in this Thread,
I got lotsa good info about creating menu's here. I have a question.
Can i add an introductory video with TmpgEnc DVD Author before the main menu.
So as soon as the DVD is inserted, the intro video play first and then the
main menu appears ?
(Intro video is something...this video belongs to or created by XYZ)
Any idea's ? Any tricks ??
Praveen73 -
I just put the answer in your other thread. :c)
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
....and I just confirmed it.
Very useful info about backgound audio to menus here. Thanks to all.
I was making a DVD for a friend so I wanted to add a video that started when the DVD was inserted into the machine, along the lines of the familiar "DO NOT COPY THIS VIDEO etc etc".
I used Ulead VideoStudio to create the text "warning" saved it as a mpg. Then also constructed a "trailer" using UVS including some of the effects etc for around 30 seconds. Then joined the two together and it works great. Follow Gees guide in the above thread. The short section runs when the DVD is inserted then it goes to the main menu.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 20:33 -
TMpegEnc DVD Author won't fill a 4.7 GB DVD
By jagojon3 in forum Authoring (DVD)Replies: 12Last Post: 29th Dec 2008, 18:32 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 01:23
