Hi,
i've seen review about the sound quality of LOTR 1 saying that DTS track sounds better than the track DD 5.1. So, in your opinions, do you believe, if i made a conversion from DTS track to DD 5.1 track, that my DD 5.1 track would be better than the original DD5.1?
Tks.
Tharkysis
In short - No it wouldn't.
The reason the DTS sounds better is that it uses much less compression than a DD track and thus provides a better sound. By recompresing the DTS you will get a WORSE than original DD soundtrack as you do not have access to the original UNCOMPRESSED soundtrack - only the studio will have access to this. -
Originally Posted by TeeeRex
well i'm not sure....
What's the max supported DD bitrate, and what's the original bitrate used on the disc?
If there's a big difference between the two, there would be a noticeable difference in quality (but i'm talking if it's 768kbps max, and the normal is only 384kbps)
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
