Anyone know of a good (preferably free) "undelete" app for NTFS? I deleted a movie (that I had really put some effort into) by accident last nite, by habit holding the shift key pressed as I hit Delete and Enter in rapid succession... (Yeah, I know...)
/Mats (Heading out on a Google search)
I had a post about this. I'll try and dig it up.
WARNING: do not do anything to the drive of which the file was stored on or you risk overwriting the file!!! -
Here: https://www.videohelp.com/forum/viewtopic.php?t=175028
It is concerning a DVD-RW (which I could not recover) but all the programs suggested should work with NTFS.
Try one of them to see if you can still recover the file, and if you can, maybe buy a program just in case it happens again, or try a search on google for a free app. -
Nope, that one showed the file, but as 0 bytes... On to the next!
Thanks for your concern, tho...
/Mats
Trying to fix a .mov that was corrupted after using undelete software
By Elderain in forum Newbie / General discussionsReplies: 10Last Post: 11th Oct 2012, 13:47 -
Undelete software
By kyrcy in forum ComputerReplies: 8Last Post: 31st Jan 2011, 03:27 -
Diskeeper UNdelete Vs Get Data Recover my Files
By mn072065 in forum ComputerReplies: 5Last Post: 26th Aug 2008, 12:26 -
request advice concerning undelete files accidentally lost.
By kasfig in forum Off topicReplies: 5Last Post: 21st May 2007, 16:19
