What codec pack do you use?
I've had to many issues with codec packs, I prefer to get the individual codecs as needed.
cheers, this is the kind of feedback I'm looking for, as i've recently started getting problems with the packs.
Only tried Nimo once, but that experience was enough to make me stay very clear of anything that has "codec pack" in its name. Almost had to reformat.
/Mats -
I agree with the others - I've only had trouble with codec packs (exactly the same as Mats in fact).
There was another post about this somewhere, but people seemed to agree that there was probably a 'core' of codecs most people use.. something like:
* DivX - latest version.
* Xvid - a few different distributions available - just get the one linked to in the Tools section if you're not sure.
* AC3Filter
* MPEG2 codec - there's a freeware one available, but you can also get one by installing PowerDVD / WinDVD etc..
* mp3 audio codec - use the Lame MP3 ACM Codec
tooLame (and all the other comandline apps used by BeSweetGUI) are also handy if you're doing conversions etc.. - although these are not strictly-speaking codecs.
Other than that, it depends what you want to do with your PC.
For example, if you're doing capturing, you might want HuffyUV and/or one of the MJPEG codecs, or some DV codecs for example.
My approach is to install the main ones I know I'm going to need (i.e. those above), and then just use gSpot to tell me what codec(s) I need if I come across a file that my existing codecs won't support.
cheers,
mcdruid.
What is the best Codec Pack?
By cim in forum Software PlayingReplies: 84Last Post: 8th Jul 2012, 11:45 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 6Last Post: 2nd Feb 2012, 21:39 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 1Last Post: 27th Jan 2012, 13:44 -
K lite codec pack
By Pumkinhead in forum Newbie / General discussionsReplies: 14Last Post: 26th Oct 2010, 13:12 -
Codec Pack selection?
By therock003 in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2007, 10:50
