  1. hello I'm using Ulead moviefactory 2 to burn a movieclip file that's about 700 megabytes. The sound in the file is mpeg-layer 3 and the "video codec" is Divx. When I load the file into Ulead it's bigger than 4,7 gig!
    Is there anything I can do about this?
    ps. I'm from sweden so please forgive any misunderstood or bad transelated words above. ds
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You have to lower the bit rate for the video, or use some compression for the audio (does Ulead create LPCM audio tracks only?) track.
    I don't know MovieFactory, so I can't tell if any of those options are available.
    /Mats
  3. Well i don't know how to lower the bitrate but you can chose mpeg audio
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I might suspect Ulead to use the word "quality" instead of bit rate - lower q meaning lower bit rate...
    /Mats
