I'M GETTING DOUBLE IMAGE AFTER ENCODE WITH TMPEG XSVCD (LAST VERSION) I LOAD DIFFERENT TEMPLATE,TRY TO ADJUST WITH ANY FILTER POSSIBLE,BUT CAN'T FIND THE SOLUTION..
ANY HELP WELCOME
WELL THE FIRST THING YOU NEED TO DO IS TO turn off your caps button.
AP Enterprises Ltd. -
What is 'double image' ? You meant some sort of mirror effect?
There's a GOOD chance you meant your video turned out Interlaced with scanlines. Try using DeInterlace filter with Even-Odd (Field) settings.
<font size=-1>[ This Message was edited by: Jeomite on 2001-10-04 15:15:43 ]</font>
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
double image when copying with Convertx
By agent222 in forum Authoring (DVD)Replies: 1Last Post: 19th May 2010, 15:39 -
Double image!!
By Cabal2000 in forum Authoring (Blu-ray)Replies: 11Last Post: 5th Feb 2009, 14:00 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
