Audio keeps skipping and there are some video glitches to the VCD. I'm using Pentium4 1.8ghz with 256 SDRAM. Give up?
rdj95,
we're going to need far more detail if we're going to be able to be helpful.
1. What is your source? DVD rip, avi file (if so, which codecs? - use gSpot) etc..
2. What is the quality of your source like? (especially the audio)
3. What settings are you using in DVDx? (and which version are you using?)
4. Are you producing a standards-compliant PAL/NTSC VCD? or a xVCD/SVCD/xSVCD etc.. (related to DVDx settings)
5. How are you authoring/burning your (S)VCD?
6. How does the (S)VCD play on your PC as opposed to your standalone?
That should give us some more to go on...
cheers,
mcdruid.
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 23:57 -
DVD to XVID using DVDx 2.20
By Immortal25 in forum DVD RippingReplies: 0Last Post: 2nd May 2010, 07:20 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 02:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 09:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 15:17
