I'm sure this has been covered before, but with new versions of ffmpgX and FortyTwo, as well as Capty, Toast 6, Sizzle and iDVD, I'm getting confused!!!!
All I want to do, is make some DVD's consisting of TV eps averaging around 425 megs each that were converted from Replay or EyeTV.
iDVD says I need Quicktime .MOV files, well I convert them using Quicktime to .MOV, and it says unsupported MPEG file? Huh? How do I get a TRUE .MOV file?
Toast gets rolling along fine, but comes up with "problems with source file" errors halfway thru, any pointers on fixing that one?
Sizzle does much the same, but decides to crash the whole system instead.
ffmpgX used to convert at blinding speed, but now trudges along, with it being the only program running?
FortyTwo just spins along for up to an hour before I get frustrated and kill it, I've yet to do anything with it.
For the record, G4 350, Gig of RAM, 10.2.6, latest Quicktime, etc and backing up DVD's is a breezer using DVDBackup and DTOX, but somehow, what should be a simple task is driving me nuts!!!!!
If any of the bright people in here can post a tutorial that doesn't require a degree in Computer Science to comprehend, I will be eternally grateful!!!
Too, too complex, in DVD Backup and DTOX, we've got drag and drop simplicity, I'm looking for something similar for my purposes. My point is that iDVD, Toast and Sizzle all (supposedly) will do the re-encoding, but none seem to do so succesfully, leading me to beleive that some re-encoding must be needed beforehand, despite what these programs claim. IS there a solution that DOESN'T require 137 hours of re-encoding that will bring my Mac to a crawl for me to make a few DVD's? What about DVD Studio Pro? Is that a little more industrial strength than iDVD?
do the ifogen/tocgen for the .mpeg and you will get directly a video_ts folder
just skip ahead to the part where its talking about mpeg demuxing to convert audio to dvd standard. If you alreay have it muxed at dvd standard, just skip to the ifogen stuff.
Its really easy once you do it the 1st time, i promise. I can even do it with my eyes closed now....
if it errors on this method, then something is wrong with the mpeg files. -
either way, if you keep getting errors on whatever method you pick, there could be some problem with the individual mpeg files
help required on making simple but 'deep' dvd menus
By lancealittle in forum Newbie / General discussionsReplies: 9Last Post: 18th Sep 2010, 06:34 -
New to video making. I have a few simple (I hope) questions.
By BornRuffian in forum Newbie / General discussionsReplies: 1Last Post: 27th Apr 2009, 00:01 -
Need simple guide on making AVIs compatible with Xbox360
By sad_muso in forum DVD RippingReplies: 4Last Post: 22nd Aug 2008, 13:12 -
Making simple DVD from 16x9 avis
By clawg in forum Authoring (DVD)Replies: 4Last Post: 1st Nov 2007, 21:47 -
Pioneer DV-400 - avi/mpeg off flash drive?
By snowverkill in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Jul 2007, 18:11
