I don't have any more pci slots open but I would like to record FM radio on to my computer from live radio. Are there any companies that will make something I want??
localfinesse
Unless you have a reason you want it in the computer, you could just use your line in on the sound card.
Take about any radio or stereo that has a headphones jack and connect a cable into that and into your sound card. That's what I did to record some of my cassette tapes to cd.
If you have a line out jack thats better, should give a constant volume level. If you use the head phone jack then the volume control on the radio will also adjust your recording volume, so you might want to mark it when you find the correct level you want. My radio/player had a slider so I just took a knife and put a scratch where I wanted to set it. Then before recording I just make sure the slide is next to the scratch
No need to buy extra stuff other than a cable with the correct plugs, or a set of adapters if you need a size like those old fashion large plugs! -
Have a look at
http://www.averm.co.uk/products/USB%20Radio.html
which looks to be just what you are after. Strangely enough though, there's no mention of it on Avermedias US website but there is on the UK one. In the UK it costs under £30 ($48) from http://online.stak.com/cgi-bin/stak/ (search for item 41960704).
Should do the job you want perfectly. -
Actually I just got the dlink from ebay I hope it works good.
Thanks for the replyslocalfinesse
What type of music do you listen to?
By johns0 in forum PollsReplies: 19Last Post: 5th Mar 2011, 21:26 -
Is There Such A Thing??? re: Pinnacle Studio 500 USB
By drtalk in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2010, 20:21 -
Do you listen to Sports Talk radio?
By yoda313 in forum PollsReplies: 18Last Post: 27th Feb 2008, 10:11 -
Do you listen to streaming internet radio?
By yoda313 in forum PollsReplies: 13Last Post: 25th Jun 2007, 21:54 -
What podcasts do you listen to?
By stryker in forum Off topicReplies: 3Last Post: 17th May 2007, 14:56
