i have downloaded some films mostly avi xvid codec but when i go to encode then tmpge says that it cannot encode it as file cannot open or is unsupported can any one help please help but make any advce simple as im just starting out
Since you are new I'll help you... But you have to go get a couple of more programs. You'll need Virtualdub and VirtualDub Mp3 Freeze
Now with downloaded movies from the net I take it You you'll have to go inside TMPGEnc and change VFAPI settings There you'll find one for DIRECT SHOW increase that one so its on top of the list.
I assume that you can play the avi file on your computer right? if you can't you need the DivX codec but I'll assume you have it.
Once you raise the VFAPI value of Direct show TMPGEnc will work just fine.
Here is the big but...Before you start encoding make sure you run the avi through VirtualDub MP3 Freeze to make sure you have no bad frames (a very common problem with downloaded movies from the net) If it comes out clean then do your thing with TMPNGEnc if bad frames are found delete them and save the new avi....It gets complicated here so if you need more info e-mail me and I'll send you my guide for newbies...
doctorag2003@yahoo.com
ArchieThink Before You Do It
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 21:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
