I have an unmodified Apex 600A with loophole menu, and it's been extremely tempermental about playing svcds or xsvcds. Often it will play and then not play the same exact disc (more often not playing). I've wondered if getting some updated firmware might help, if not a new player.
Anyhow, what I've been doing which works consistently is capturing in MPEG2 with my DVC II, and then re-multiplexing it in TMPGE using the MPEG-1 VCD Non-Standard setting. I've done this with resolutions of 352, 480, and 720 (x 480) at bit rates up to 4500. My question is, does the playback suffer compared to a true SVCD or XSVCD when I multiplex the same MPG2 as a VCD?
What's nice is there's no reencoding, so I can capture in real time and get decent results. Since I can almost never play an SVCD in the Apex, I can't compare a regular SVCD with the same stream remultiplexed as mentioned. Any thoughts?
If you have problems with SVCD, you can multiplex as XVCD (Video-CD non-standard). Since it is the same MPEG, the playback wont suffer. But you lose all the SVCD advantages, like 2 audio streams/ subtitles. Maybe the a 4500 bitrate is a little to high for your player.
Strange sound problem during .mkv playback
By choracy in forum Software PlayingReplies: 4Last Post: 19th Oct 2013, 06:39 -
Strange VCR Playback Issue
By ejk71 in forum Capturing and VCRReplies: 2Last Post: 2nd Apr 2011, 22:17 -
Strange artifacts during video playback
By shiningwizard in forum Software PlayingReplies: 0Last Post: 9th Feb 2011, 10:37 -
Strange Issues With .AVI playback
By munky261 in forum Software PlayingReplies: 1Last Post: 27th Sep 2009, 05:50 -
Strange artifacts on DVD playback
By polara64 in forum DVD RippingReplies: 6Last Post: 12th Sep 2009, 14:35
