Hello,
I tried to use VurtualDub to find out specs of an AVI file.
First of all, strange enough, to open it VirtualDub had to "resonstruct index block" ....
Then audio showed up as stereo 5 channels with UNKOWN TAG 2000. What's this? When I try convert it to MPEG with TMPGENC, I get no sound, I think I have all possible codex installed, maybe not? help!
I think "unknown tag 2000" is AC3 audio.
A man without a woman is like a statue without pigeons. -
This is just a guess, but you could download the Nimo Codec pack (look on google for it I guess) and make sure the AC3 filter is installed with it (should be automaticly installed) and see if it plays then.
Even though I get Uknown Tag 2000 message in VirtualDub i still can play this avi file in real player, no problem... but I just cant convert it to MPEG with sound....
VirtualDub uses ACM decompressors. So install an AC3 ACM decompressor. AC3Filter is a dshow decoder. TMPGEnc also by default uses ACM, that is unless you change the dshow input priority.
audio tag 0162
By lroixx in forum AudioReplies: 11Last Post: 22nd Oct 2015, 05:27 -
Changing the name tag of a DVD audio track
By DeathStalker77 in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2012, 12:01 -
Uknown DVD - Is First play track the problem (TMPGEnc Author Works 4)
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 22nd Apr 2011, 07:26 -
Wrong audio codec tag/label!!
By Ijaja in forum AudioReplies: 2Last Post: 28th Sep 2010, 03:32 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 22:51
