Since you're remuxing the files, could you add an option to specify an audio offset. Something in the range of +/- 30ms is all I need. This should be at least theoretically possible, since I've seen other programs do it. If possible, this should be done without transcoding the audio.
I'm not suffering from the audio sync issues other have complained about here. It's just that I have a set of files that are out of sync by a small known amount.
As an economic incentive, I should point out that this feature alone will probably get you 100+ customers. This would make svcd2dvd the best authoring app out there for PVR ripped mpegs.
Guest
This should be possible
IfoAR2WS Feature Request
By TheArtfulDodger in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 13:36 -
feature request: Vob2mpg pro command line option for audio stream selection
By Ahimoth in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Sep 2009, 06:42 -
New Feature Request - DVD Title
By noyou in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 17th Sep 2008, 08:25 -
Feature request - auto titles
By Neil Herber in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th May 2008, 13:49 -
Feature request - autofit adjustments
By Neil Herber in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 12th Sep 2007, 14:34
