I have a mpeg 1 (not mepg2) file that has 2 audio streams (english + Japanese). What program can I use to separate the 2 audio streams? I can de-multiplex the audio from the video but I still end up with 2 audio streams.
Thanks[/i]
Hi,
I'm pretty new to all of this, which means that I've spent ages trawling through forums and guides etc.
I've seen quite a few mentions to VirtualDub as a good piece of software (freeware) that may be able to help.
There are also a fair few guides from the links on the left.
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
MPEG2 video supports multiple audio streams. MPEG1 videos do not. I suspect that what you have is one audio stream with english on channel and japanese on the other. So you'll want to spilt the left and right channel to sperate audio files.
You can do this with several wav/audio editing programs. I use/like CoolEdit.
Separating Audio Layers From .AVI File
By PhoenixOrion602 in forum AudioReplies: 2Last Post: 5th Jan 2011, 23:58 -
separating audio and re-authoring
By joecass in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2010, 10:37 -
Separating the channels in a 5.1 stream into separate streams
By FallenAngelII in forum AudioReplies: 2Last Post: 7th May 2010, 02:37 -
Separating audio
By Jeikobu in forum MacReplies: 12Last Post: 9th Jun 2008, 04:39 -
separating audio files
By lordwade in forum AudioReplies: 1Last Post: 11th May 2007, 03:32
