I just want ask how / what program I use to burn DVD video to fit more than 120 min. on a DVD. A blank DVD have 4.7 gb but is i burn is as video is only 120 min. Is there any method to burn so that is can fit more than 120 I assume is can fit alot more than 120 min. I don't mind if the qulaity is lower like vcd I just want to know how to fit more min. into a dvd
thank you.
Lower the bitrate of the files, until you get all the files combined equal less than 4.3 Gb's.
You can put 6 hours on a DVD, but it won't look good. -
I wanted to burn mpeg file on the DVD, DVD Shrink is to convert the file from DVD. It there any program or method to make the mpeg file fit up to 6 hr on a DVD. How do I change the bitrate rate can i do that wiht Tmpeg. ?
Any video download services that let you burn to dvd-video?
By yoda313 in forum Off topicReplies: 1Last Post: 26th Dec 2009, 17:09 -
How to burn high definition video to DVD?
By local2 in forum Video ConversionReplies: 1Last Post: 13th Dec 2009, 14:53 -
How much video can I burn on a DVD 5
By Sikander in forum Authoring (DVD)Replies: 15Last Post: 15th Mar 2008, 11:30 -
How do I burn/copy video to dvd
By cschinnerer in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2007, 20:33 -
Trying to burn a mpg video file to DVD
By bhxtyrant in forum Authoring (DVD)Replies: 8Last Post: 11th May 2007, 15:22
