  1. i want to upload some small movies onto the internet.
    I was just wondering what format i should put them in, now i would like the file's to be as small as possible but also remain good quality. I was thinking DivX but then i thought most people will be using wmp and that isnt compatible.
    can anyone recommend a good format to use?
    thanks
    Apr 2002
    The State of Frustration
    Wmv is usually the way to go. If you must use mpeg, tell your clients to download the files and play them then. Use mpeg-1 if you do go this way, as media player has few problems with them.
    Hello.
