Hy,
I’m new here and glad to join your forum.
I have a question concerning my standalone DVD Player (Philips 634), which I bought a few days ago and hope you guys can help me out.
I’ve tried to play a SVCD movie of a friend of mine with the DVD player but unfortunately I get the following message:
DISC LOADING
MP3 – JPEG
FIND: 0
INVALID ENTRY
I'm am a beginner in DVD stuff
I've never burned an SVCD because i don't have a cd-burner.
The CD implies the following directories:
EXT
MPEG2
SVCD
The main movie file (MPEG file, about 720 MB big) is in the MPEG2 directory.
The movie is burned on a 90min (800MB) CD.
I have no problems playing the SVCD movie on the computer with PowerDVD by running the mpeg file from the MPEG2 directory.
Am I doing something wrong?
Do I have to change DVD settings?
I hope you have some suggestions for me.
Thanx
Regards
Nikolai
p.s. I’m not sure if this is the right forum, so I’m sorry if not.
does it work on dvd and vcd? does this disc work in other dvd plyer?
Ur plyr do svcd?? not all can!Corned beef is now made to a higher standard than at any time in history.
DVD's workOriginally Posted by RabidDog
VCD - i have no VCD's and never tried one
The player should be able to play SVCD's
My TV doesn't run either .DTS and .AC3 file from .MKV movie
By galodoido12 in forum AudioReplies: 2Last Post: 4th Feb 2012, 00:29 -
Philips 42PFL9664H doesn't automatically detect when a DVD is started
By holmerz in forum DVD & Blu-ray PlayersReplies: 3Last Post: 10th Aug 2010, 09:18 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Run TV and have DVD player cut in
By kevinreddog in forum Newbie / General discussionsReplies: 4Last Post: 20th Jan 2008, 12:33 -
Run TV and have DVD player cut in every 15 minutes?
By kevinreddog in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Jan 2008, 08:31
