I have a VCD that has two langauges, english and Japanese. I use ISObuster to rip the vcd file format into mpeg1 format onto my computer. I can play the resulting mpeg1 file on my computer fine. Both Japanese and english are present in the mpeg1 file. If I move my wave slider (in volume control) to the left i I get all english and to the right I get all chinese.
The problem is this, I have tried reencoding the mpeg1 file into a smaller file so i can play it off my pda. For some reason tmpgenc will not detect/encode both audio streams it only encodes the Japanese stream. I did a mutiple 1 minute encode tests and each resulting mpeg file only has one audio stream. All in Japanese
Next I used audio/normalizing feature in tmpgenc to see if both audio streams were detected and I found that tmpgenc only detected the japanse stream and not the english one.
I tried simple demutiplex, de-mutiplex and the audio file from the video file and I got was japanese, the english audio stream was gone.
THe strange thing is that if I didn't re-encode, but just did an edit of the credits or a section of the movie the audio streams would remain in tact.
Another strange thing was that this only affects this VCD/mpeg1 file. I have other VCDs/mpeg1 that were re-encoded with no problems using the same settings. Those files have both audio streams still in tact. Actually when this VCD/mpeg1 file didn't work I tried another one and going through the same steps i had a smaller mpeg1 with both audio streams present.
So how do I get both audio streams or at least get the stream that I want? Both audio streams are present on the mpeg1 file when I play it without editing.
Not sure if this will work but might be worth a try. Use Tmpgenc mpeg-tools to de-multiplex the VCD to seperate video (.m1v) and audio (.mp2) files. Now re-encode just the video section how you want it, then re-multiplex the newly encoded video stream with the audio saved out earlier.
Hope this helps. -
"Not sure if this will work but might be worth a try. Use Tmpgenc mpeg-tools to de-multiplex the VCD to seperate video (.m1v) and audio (.mp2) files. Now re-encode just the video section how you want it, then re-multiplex the newly encoded video stream with the audio saved out earlier. "
The minute I de-multiplex the mpeg1 file I lose the english audio stream.
It's very weird. Yet it lets me edit fine in tmpgenc.
Question how to capture this audio stream and turn into mp3
By jimdagys in forum AudioReplies: 22Last Post: 7th Nov 2013, 12:46 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
Question how to capture live audio stream of KJAZZ
By jimdagys in forum Video Streaming DownloadingReplies: 7Last Post: 13th Nov 2010, 19:26 -
Question about number of listeners to a particular audio stream
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 20:57 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
