I've obtained an avi which has sound format 2 channel A3 DVM, when I put it thro TMPEG or NEODVD it converts the picture fine but there is no sound, if I play the AVI thro media player it plays fine with sound, am I missing something, I've done other AVI's no problem but I don't recall what sound format they were. Any ideas anyone please.
Thanks for the reply , yes I did add the audio avi file into the audio part, what do u mean by upsampling the audio ??? because I don't do that ??
As you have ac3 audio you need to convert so that tmpgenc can use it. Do a forum search on CONVERT AC3 and you will get some old posts that will help you.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
AVI converting sound issue
By wickerstick in forum Video ConversionReplies: 1Last Post: 23rd Jul 2009, 06:53 -
Sound problem when converting AVI to DVD
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2009, 17:12 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56
