I have a .MOV file that I converted from an AVI. It plays fine in QT, but when I try to import into iMovie, the audio gets all choppy.
I noticed the .MOV has 6 Sound tracks, I tried t oextract them to an .Aif and then repaste, but it didnb't work. ffmpeg is also unable to process the audio to an mp3.
Any ideas what might be causing this, or how to fix it? I'm about ready to give up on it as being too corrupted.
what speed is your machine? It might just be latency. Have you tried exporting the movie and playing that back in Quicktime to see if it is still choppy?
It's a dual 1ghz G4. I shouldn't be having cpu problems.
I think I did try exporting and I lost some of teh audio. What type of export would you recommend? -
with a DP 1GhZ you should definitely NOT experience any latency.
I cant tell you what settings to use for export because i do not know what your target is... email? dvd? Divx? VCD? -
Ultimately, I want to use to put this on iMovie for a DVD using iDVD.
I went to convert it to an AVI using the QT avi export, and the file was HUGE!
maybe my fps were wrong? I was using 29.97 I think. for avi, should I use 15 or so?
Problem wit .MOV files on iMovie
By Maurem in forum MacReplies: 5Last Post: 9th Sep 2013, 00:54 -
ffmpegX: no sound when converting a imovie *.mov-file
By acid_burn in forum ffmpegX general discussionReplies: 2Last Post: 27th Dec 2011, 00:40 -
xdcam to .mov so I can edit with iMovie????
By boriega in forum Video ConversionReplies: 3Last Post: 15th Sep 2010, 00:39 -
Problem with converting MOV files from iMovie / Camera
By pred02 in forum Video ConversionReplies: 1Last Post: 23rd Sep 2009, 02:25 -
VOB to MPEG to MOV to export to iMOVIE HD 06 HELP PLEASE!
By HowardNeedsHelp in forum MacReplies: 5Last Post: 16th Aug 2009, 06:15
