Hello all... I have a bin/cue of an svcd and I have used nero to burn it to cd but I get an audio sync problem in my stand alone dvd player (not on my pc though). I have tried other software and burning at slower speeds with no avail. I have tried some other bin/cues of svcd's but they all seem to get an audio sync problem aswell now. Can anyone suggest different software maybe or what the problem is?
Thanks![]()
check out dvd2Svcd (signature). You could use isobuster to extract the audio/video and then cut out or add in the audio gap/extra using TMPGENC, if you feel adventerous enough or read over one of the guides that shows you how to do it.
Is the sync issue 2-3 seconds all the way through or is it in and out of sync? -
Its in and out of sync about 1-3 seconds... also if I stop it and resume it, it will be ok for a few seconds and then go out of sync again. Its weired because it never used to do this? So could there be a problem somewhere else?
Thanks for your reply -
Could be that the total bit rate is too high for your player? Some SVCD players have trouble above 2200-2300 total bit rate.
/Mats
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
Audio Sync Problem That I Do Not Understand
By Anakin in forum DVD RippingReplies: 20Last Post: 25th Feb 2009, 10:32 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
