Looking for help on the following:
I have a Sony DRU-510 (1.0c) and am having trouble creating DVD-R discs. The machine is a Dell 2.2GHz Win_XP Pro 256MB, 120MB HDD and should have plenty of horsepower to handle what I'm trying.
Formatting, and writing to DVD+RW is no problem, but when trying to convert old analog tapes to DVD-R I get system crashes. I'm using Sonic MyDVD (ver 4) software bundled with the Sony drive, the process seems to work fine as far as reading in the analog source and saving a temp file to the HDD, but when beginning to write to the DVD-R I get a blue screen with a message that there is a problem with dvd_2k.SYS. The system hangs and only a hard restart will bring it back. I don't know if it is a H/W or a S/W issue. Any help would be appreciated.
What software are you using for burning ?
"Sonic MyDVD" (ver 4) supposedly takes care of the burn process. I'm considering creating the DVD image to HD in that software and then using something else (maybe a program like Nero?) for the burn operation.
i too have xp pro... which takes up at least 120mb at start up with little apps running ....most burning apps have default buffer of 128mb when burning dvd's. you only have 256 mb ram so if you are running other apps your really asking for it . at least 512 ram is recommended. also i hope you have a good power supply cuz many people overlook that it is the most important part of your computer, keeping your parts in good health and providing enough constant juice, lack of power will cause instabliity problems. 8)
ITS DIRTY CAPTAIN MAYBE CHECK THE UNITS COOLING AND VOLTAGE SUPPLIES ,USE A 400 W POWER SUPPLY .
I JUST REPARED ONE WHERE THE PROBLEM WAS POWER SUPPLY WHEN IT WENT TO BURN CAUSING HARD DRIVE FAILURES AND VIDEO LOCK UP DUR TO POWER SUPPLY RAIL
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Sony RDR HX 510 and DVP NS 305
By SearchQuality in forum MediaReplies: 10Last Post: 16th Nov 2007, 11:41 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 18:40 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 22:55
