Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Guest
    When doing an ecode with the new 1.5, I get the following error:
    Starting SVCD2DVD: v1.5.1336.21117
    Begin time: 3:30:13 AM
    ******** Ripping SVCD images to get mpegs
    ############### New MPEG File ###############
    File: M:\video\SheSPies\EXTRA.080407D30103020F_edited.mp g
    Horizontal Res: 544
    Audio SampleRate: 48000
    ******** Demultipexing original mpg file
    ******** Resampling audio from 44.1 KHz to 48 KHz
    Skipping....
    ******** Multipexing elementry streams
    D:\winapps\SVCD2DVD\mplex.exe: *** shared version mismatch detected - 0x18A20049/0x18A2004E.
    You have multiple copies of cygwin1.dll on your system.
    Search for cygwin1.dll using the Windows Start->Find/Search facility
    and delete all but the most recent version. The most recent version *should*
    reside in x:\cygwin\bin, where 'x' is the drive on which you have
    installed the cygwin distribution.
    M:\video\SheSPies\EXTRA.080407D30103020F_edited_DV D.mpg is not a valid mpeg file
    ||||||||||||||||||||||||| PROCESSING ABORTED |||||||||||||||||||||||||
    I noticed that you ship your own cygwin libraries with svcd2dvd. Well, I have other programs that ship with their own versions of cygwin, as well as having the standard cygwin distribution installed. So I can't just go around deleting them. Please fix asap.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    can you try renamimg cygwin1.dll in the svcd2dvd folder to something (e.g cygwin1.dll.svcd) and then copying the dll from your cygwin install the svcd2dvd folder.
    Failing that I'll embark on a fix build
  3. Guest
    That worked. I replaced the following three files:
    cygwin1.dll
    cygxml2-2.dll
    cygz.dll
    This also seems to solve my problems with dvdmenumaker randomly crashing.
    My cygwin files older than yours, so on the next release, your installer will probably overwrite them with your files and cause this problem again.
