Hi all
Until a few days ago i had no problems in accessing my hotmail account, i have tried accessing the hotmail website in aol 8 and internet explorer 6. I also have another PC which gives me the same error message In aol 8 i recieve the following message
Now i figured there are 2 possible reasons,
1) a problem at hotmail which they need to sort out
2) my antivirus programme notified me that i had the a virus W32.Kwbot.F.Worm. After an initial scan norton 2002 didnt find anything although my definitions are upto date and thereafter i proceeded to remove the virus by following the below instructions.
http://securityresponse.symantec.com/avcenter/venc/data/w32.kwbot.f.worm.html#removalinstructions
1) Virus definitions are updated.
2) i couldnt end the trojan process using the task manager because there was nothing of sort, unless its been renamed.
3) i scanned all files before and after detecting virus and nothing is found.
4) (The hard part) completed steps a to c, deleted the value in step d (made a back up of registry), didnt complete steps e f & g as i couldnt find anything that i was looking for.
Q1) Now by messing with the registry have i some how messed up removal process which is also affecting me accessing my hotmail account?
Q2) Is the virus (trojan) still there which is affecting my me from accessing my hotmail account (although norton says its not) and have i partially removed the virus.
Q3) How do i undo the changes in the registry, do i just double click on the backup registy and click yes to the warning box?
thanks for your advice
kas
[/img]
I cannot say for sure, but I do not have the entry you deleted in my registry and my hotmail works as of my posting.Originally Posted by kas187
Tough call as well. I read the instructions and it looks as if step d of the instructions is what will stop it from running on your computer.Originally Posted by kas187
Steps e & f are to prevent it from spreading over P2P programs. Therefore, I would wager that it is not running on your computer.
That should work, but here are the directions straight from microsoft...Originally Posted by kas187
HOW TO: Back Up, Edit, and Restore the Registry in Windows XP and Windows Server 2003
EDIT: it also seems that this virus does not do anything automatically except propogate. It has to have a hacker on the other end to actually do any damage. In order for it to contact a hacker, you have to have port 6667 avialable as an outgoing port. If you are running a firewall, the good ones will notify you of a program attempting to send data outward (the built-in firewall with windows will not do this)"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Solarjetman
Thanks for your reply, much obliged.
I have found out why i have problems accessing my hotmail and thats due to AOL having problems on their end but should be remedied soon, hopefully.
Currently i am running nortons personal firewall, so hopefully this should keep me safe for a while, i hope.
thanks for all the advice, its put me at ease now.
kas
I can't access the free DVDFab HD Decrypter anymore - Why?
By JohnnyBob in forum DVD RippingReplies: 25Last Post: 16th Mar 2014, 19:36 -
An out-of-bounds memory access (access violation)
By rjc7394 in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 18:42 -
Virtualdub....An out-of-bounds memory access (access violation) occurred...
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 8th May 2010, 01:40 -
Track Access / Menu Access
By chulew in forum Authoring (DVD)Replies: 3Last Post: 15th May 2008, 18:31 -
Virtualdub - out-of-bounds memory access (access violation) Lameacm
By kidcash in forum Video ConversionReplies: 1Last Post: 21st Jan 2008, 09:34
