    Aug 2003
    Australia
    Hi there,
    I'm still new to backing up & came across the following message today while trying to back up "Legally Blonde" using DVD Shrink v3.0 beta
    "DVD Shrink encountered an error & cannot continue
    Failed to read from file
    The reason is: Copy Protection error - The read failed because the sector
    is encrypted"
    Is there anyway to get around this? I tried to search to find an answer with no luck.
    Mar 2003
    Las Vegas, NV
    I got that same message recently after I had backed up several movies previously with no problems. However, I had just installed a new DVD Rom drive. I went to the Lite-On site and downloaded new firmware for the drive, and no more error messages.
    You might want to check the firmware of the drive that you are ripping from.
    Burn Baby Burn
    It's a Disk-o Inferno
    Apr 2002
    The State of Frustration
    Sure. Play it for a minute.
    Hello.
  4. Rip ALL files with DVDDecrypter to the HDD and open the files in DVDShrink instead of DVD disc. It might help
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
