Hi guys, I am trying to convert several .mov files into vcd. I use the standard vcd preset of ffmpeg, deselect the author for vcd option and select split in 3 chunks. All the movie conversion failes and the log is:
++ WARN: [mplex] Target data rate lower than computed requirement!
++ WARN: [mplex] N.b. a 20% or so discrepancy in variable bit-rate
++ WARN: [mplex] streams is common and harmless provided no time-outs will occur
INFO: [mplex] Run-in Sectors = 35 Video delay = 40232 Audio delay = 43832
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 94208 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Padding : sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=6990095 required(DTS)=6989016
++ WARN: [mplex] Video e0: buf= 82077 frame=001921 sector=00003840
++ WARN: [mplex] Audio c0: buf= 2389 frame=002941 sector=00000944
++ WARN: [mplex] Padding : sector=00001265
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=7334944 required(DTS)=7331016
++ WARN: [mplex] Video e0: buf= 91903 frame=002015 sector=00004094
++ WARN: [mplex] Audio c0: buf= 4096 frame=003084 sector=00000990
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=7679794 required(DTS)=7665816
++ WARN: [mplex] Video e0: buf= 91912 frame=002109 sector=00004348
++ WARN: [mplex] Audio c0: buf= 4096 frame=003227 sector=00001036
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=8024643 required(DTS)=8000616
++ WARN: [mplex] Video e0: buf= 91912 frame=002202 sector=00004602
++ WARN: [mplex] Audio c0: buf= 4096 frame=003371 sector=00001082
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=8369492 required(DTS)=8339016
++ WARN: [mplex] Video e0: buf= 91903 frame=002295 sector=00004856
++ WARN: [mplex] Audio c0: buf= 4096 frame=003514 sector=00001128
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=8714342 required(DTS)=8677416
++ WARN: [mplex] Video e0: buf= 91903 frame=002389 sector=00005110
++ WARN: [mplex] Audio c0: buf= 4096 frame=003657 sector=00001174
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=9059191 required(DTS)=9015816
++ WARN: [mplex] Video e0: buf= 91903 frame=002483 sector=00005364
++ WARN: [mplex] Audio c0: buf= 4096 frame=003801 sector=00001220
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=9404040 required(DTS)=9350616
++ WARN: [mplex] Video e0: buf= 91912 frame=002577 sector=00005618
++ WARN: [mplex] Audio c0: buf= 4096 frame=003944 sector=00001266
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=9748889 required(DTS)=9689016
++ WARN: [mplex] Video e0: buf= 91903 frame=002670 sector=00005872
++ WARN: [mplex] Audio c0: buf= 4096 frame=004087 sector=00001312
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=10093739 required(DTS)=10092216
++ WARN: [mplex] Video e0: buf= 91903 frame=002782 sector=00006117
++ WARN: [mplex] Audio c0: buf= 3857 frame=004259 sector=00001367
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=10438588 required(DTS)=10430616
++ WARN: [mplex] Video e0: buf= 91903 frame=002876 sector=00006370
++ WARN: [mplex] Audio c0: buf= 4096 frame=004405 sector=00001414
**ERROR: [mplex] Too many frame drops -exiting
What I can do? Please help!!!!
AnonymousGuest
AverMedia HD DVR - Frame drops in live playback
By Anonanon in forum Capturing and VCRReplies: 3Last Post: 1st Mar 2012, 01:11 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Joining 2 TS streams produce glitch and frame drops
By arminio in forum DVB / IPTVReplies: 8Last Post: 7th Jun 2011, 02:30 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
NetFlix Drops HD DVD
By MOVIEGEEK in forum Latest Video NewsReplies: 24Last Post: 13th Feb 2008, 18:17
