Am I crazy or does the link on this site take you to where you can download smart ripper 2 but it doesn't include the 'Start' button? Is this b/c we live in the US?
http://www.afterdawn.com/general/disclaimers/decss_disclaimer.cfm?software_id=251&mirr...=184&x=31&y=14
I really want to make my VCD's with menus and that program looks like the easiest. I noticed only version 2 and above have the menu option.
On a different note, I wish some of my movies were better quality. Should I create VCD 2.0 instead of 1.0? Any good tips for making the video look less jagged when I play it back on my dvd player?
Thanks for any and all advice. You guys keep an incredible amount of infomation on this site. Way cool.
-Elizabeth.
The VCD standard of 352x240 1150kbit/s video is just produces a poor quaility video. Even from a DVD rip the quaility will be only ok -to- VHS master.
You're better off encoding to an xVCD at 352x480 (to capture both fields) and using a higher bitrate (1800-2520kbit/s). The problem thou is that (x)VCD use MPEG1 video which DOES NOT support an interlaced source. While this isn't a problem for backing up most movies (forcefilm in dvd2avi or IVTC) for true interlaced source it is. In that case a CVD or SVCD would be a better choice.
As for smartripper 2, I don't understand the question. Menus and stuff are done when you author your VCD and have nothing to do with the dvd ripper per se. -
Ummm, did you try clicking on the "no" button??? Is there a help file? Maybe they disabled it by default and you need to do something to make it work?
You could always get DVDDecryptor
http://www.afterdawn.com/software/video_software/dvd_rippers/dvd_decrypter.cfm"Terminated!" :firing: -
You guys are fast! Thanks.
I know it's crazy, but I noticed a screenshot of smart ripper 2.0 and there definitely is a 'Start' button. It seemed fairly straight-forward for even a semi-newbie like me. Does anyone have a different link to download it?
My DVD player unfortunately does not do SVCD, so I haven't tried it. It did mention an XVCD, so maybe that would work. I'll try experimenting with the bitrates.
How can you tell if the source (dvd) is a 'true interlaced'? Aren't most non?
So when you rip a dvd, can't you rip the menu as well and then put it together (author it) and burn it in Nero or something similiar? I guess I'm still learning...
-E. -
Hello elizard,
When I saw your post, I thought there was a new smartripper out, but alas no. Your link is referring to smartripper 2.41, which has been out for a while now and yes there is a START button that appears at the bottom, but is will only appear after you have selected the destination folder you want the rip to be placed in.
https://www.videohelp.com/vcdmenun55.htm -
Thanks you guys. I've been busy with *paid work* (is that what we call real work?) so I haven't tried your suggestions yet. I thought I did this with a destination folder, but I'll try again and see if I get the 'Start' button. Just strange.
I'm hoping DVD burners go up in speed/down in price in 6 months. Then I'm going to head in that direction.
Keep up the good work here. Fantastic site!
-E.
Avidemux and smart copy
By dexter30 in forum Newbie / General discussionsReplies: 5Last Post: 19th Apr 2015, 07:51 -
Settings for Premiere smart render/how to tell if it's working...
By rcavanah in forum EditingReplies: 8Last Post: 14th Sep 2011, 18:20 -
Get Smart backup
By Shermanbay in forum DVD RippingReplies: 26Last Post: 11th Nov 2008, 23:54 -
GET SMART no copy
By shoesss in forum DVD RippingReplies: 3Last Post: 7th Nov 2008, 09:48 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23
