Got a bunch today(3 10pks). Burn 2 coasters in a row with SCSI Target Error. This is the first time that I see this error with my DVDRW228. Going to return all the remaining ones....
The media cannot be identified by any info program I can find: SmartBurn 3.1.1, Minfo 1.6 and DVDInfoPro 2. All list as unknown manufacturer.
The disc has very poor quality looking center ring, looks like the 2 layers does not 'glue' together properly. It has the text of DVD+R KP101-13 on the inner dye ring.
One thing I noticed with my DVDRW228 is that when writing just the lead-in, it gives this unstable 'high pitch sound'.... don't know how to describe it in words. The drive gives a low volumn but high pitch sound as the motor spins I think.... but with these crappy CompUSA media, you can hear that the spin speed doesn't seem to be very stable.
Burn an Memorex media immediate after the 2 coaster, was fine.... so it was not the drive. Using Philips DVDRW228 Firmware 1.51.
I would suggest you stay away from these medias!
Min
Results 1 to 10 of 10
yeah i burn these media fine but i notcied that the bottom is very sticky. i mean like rub your fingers on the bottom of the dvd+r and you'll see what i mean. very sticky
maybe thats why your burner makes that noise -
Sounds like the binding glue leaked out from between the polcarbonate substrates when they pressed 'em together.
I believe that would qualify as a defect in workmanship? -
Never used the CompUSA DVD+R however I have burned over 200 of their DVD-R without a single bad disc.
Originally Posted by y2flyy
So y2, maybe you should keep the peanut butter and jelly sandwiches away from the computer from now on!I don't have a bad attitude...
Life has a bad attitude! -
Something actually worse than Princo. Thanks for the heads-up.
Swift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
What burner are you useing I use DVD-R compusa and no problem's. WhenI had my DRU500AX had alot of problem's with cheep media but Pioneer AO4 no problem's
Originally Posted by spiderman2k1minchin, I suggest you use RICOHJPN(TDK, Ritek, Verbatim, Fuji, Ricoh,...) discs and stay away from the others CompUSA(optodisc) DVD+ROriginally Posted by minchinYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Is the compusa sale ONLY for DVD+R? Or can you get DVD-R media instead?
My local store has the 10 packs of DVD-R on sale for $7.89 or the 50 pack for $45. I'm going to pick up another 50 pack today.Originally Posted by orbital517
Play video on windows 2003
By timmyo in forum Software PlayingReplies: 4Last Post: 20th Jul 2010, 20:48 -
OEM OFFICE 2003 Professional question
By yogart in forum ComputerReplies: 13Last Post: 5th Feb 2010, 08:05 -
Who is good with Word 2003?
By jyeh74 in forum Off topicReplies: 6Last Post: 5th Jul 2008, 17:12 -
2003 streaming service device
By arios in forum Video Streaming DownloadingReplies: 1Last Post: 14th Apr 2008, 05:32 -
Outlook 2003 question
By edong in forum ComputerReplies: 3Last Post: 28th Dec 2007, 17:06
