  1. I wanted to extract the pics from a photo VCD I created and store them on my hard drive in jpeg form. Is there a simple way to do this or is there a guide in this site that anyone can point me to. Any help will be greatly appreciated.
  2. What program are you using?Most have an option to save photos as jpgs.
    Open the disc in Explorer and look for a folder named PICTURES,if there is none you could run the disk in PowerDVD and save each photo as bmp.
    Dec 2001
    monterrey,mexico
    Hey. I suggest you author you photo vcds with nero vision express 2. When you make the slide show, it has an option to burn the pics aside in another folder, you original pics in .jpg(whatever) format. So you can play your vcd slideshow in a dvd player. And put the cd on your computer, and search for the pics in a folder, if you want to print, copy or edit them. very very useful I think try it!
  4. Where is the option of "save images to disk" in NeroVision Express 2
