Hi, I've been using DVD2SVCD. I have a legitimately purchased DVD of Half-Baked. I have been using DVD2SVCD and been converting it to SVCD.
Everything has been going fine, but I just got to this part where it takes m to this program called bbMPEG.
When it runs bbMPEG, it brings up an error which says "Input file C:\Program Files\DVD2SVCD\Movie\TitlePicture.bmp.mpv was not found."
My question, how do I get this Title picture? I've tried google, and I've searched these forums. Your help will be unbelievably appreciated!!! I'll answer any extra questions you need.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
-Robert Firth -
I had the same problem.
It is more than likely that the file itself is not missing, just that the link address is incorrect.
If you have moved the location of dvd2svcd folder at all you will get this error. Do a search for the file on your comp, if you find it go into the bbmpege section settings which willl be under dvd2svcd and make sure the link address to the file is correct.
If all else fails re-install dvd2svcd
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 20:18 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 22:16 -
Import picture/title into AVIsynth
By jwfc in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2007, 19:47
